Valve cover gasket
Onexl85
Any tips for replacing valve cover gaskets on a 5.7 merc? Should I use perfect seal on the new gasket and on the threads?
flipbro
Master Chief Petty Officer
What style valve covers. Center bolt or perimeter bolt? If center bolt with ruber gasket id say dry but im sure it wouldnt hurt anything if you did.
center bolt's generally come with a rubber gasket - just install and be done. if its a perimeter bolt, and you did not buy a rubber gasket, head to the autoparts store and buy a set of rubber gaskets for your SBC and install.
sub2010ss
Rubber gaskets are great. And don't over tighten them.
Onexl85
Is there a torque spec or a tightening sequence?
flipbro
All I have ever done is snug then a quarter to half turn more. I like how Bondo says it just use your calibrated elbow.
Ayuh,..... I Stole that from Chris, from a few years ago,....
1/4" bolts get 'bout 10/ 15 ft.lbs....
Start in the center, 'n work outward,.....
Onexl85
Ok so I broke one of the bolts trying to remove. Then I drilled it out and tried to tap but the tap broke. Had a mechanic Truro tap after the broken tap was removed and it broke again. What do yall think about three bolts and rtv on both sides of the gasket?
Sincerely
~A beaten man
