Re: vacuum switch
Weekend update:<br />Re-connected VRO, squeeze primer bulb(muffs on), ran for about 1-2 minutes and shut down as if out of gas,restarted and intermittently squeezed primer bulb, ran for more than 5 minutes OK,stopped squeezing bulb and motor shut down in about a minute,removed drain screw in float chambers, no gas escaped, squeezed bulb and removed float chamber screws, gas flowed out.<br />Logic tells me that by manually pumping gas into the float chambers, fuel is reaching the plugs and the only thing not working properly is the fuel pump.However,since I have been quoted $250 for a new pump by an OMC dealer, I just want to explore anything I might have overlooked.<br />Opinions welcomed.<br /><br />Newell
