frustratedboater
- Jul 10, 2007
- 481
Greetings all,
Boat info: 85' Mastercraft American Skier, chevy 350, Holley Carb 4BBL, vaccume secondaries..
I just switched over from breaker point system to an HEI distributor. The timing is set around 8-9 degrees before TDC and runs good (there is no vacuume hose hooked up to the distributor). I had noticed a significant diffrence in the sound as soon as I started it. I even took it out for a spin and could not notice much diffrence in performance. The engine backed down real fast from full throttle... thought that was strange...
Q- My friend who teaches engine tech, at school, installed it and said that I would need to obtain a port-side vaccume..? He said the the vaccume should be off the front-side of the carb.? I may have got that mixed up, but there was not a vaccume source for that. I tried to find numbers off the carb, but I am going off memory. 3600, or 3900... there is one capped tube towards the upper choke side, but he said that wouldn't work.
any suggestions on the vaccume source?
