Hi There chaps,my alarm constantly bleeps when I turn on ignition,prior to this it just done the short bleep and then stopped which I believe is a test bleep,it is very low on fuel in the tank which is obviously remote so presume it isnt that, can anyone advise what this is,also the two stroke tank is full on the engine and the remote one too,although I am about to disconnect the pump,any advise on the procedure for this to pevent the alarm from sounding if it had no oil in which it wont when I start to run premix, am I correct in thinking I should run on 50:1 ratio??
Many thanks in advance
Grant
Grant
