V4 Powerhead swap - what am I in for?
nateintheboat
Hi everyone,
Here is where I am at: I have a 1990 Johnson 90HP V4 crossflow flatback with a blown piston - J90TLESB. I am looking at getting a used 1980 powerhead from a 85 HP - J85TLCSA. My plan is to use as many of the parts as I can from the 1990 except for the bad block. All my research says that this will work, but here are my questions:
1. Will this work?
2. Can I use the parts from the 1990 (carbs, ignition, fuel pump, starter, etc.) on the older block?
3. I understand that some of the mounting holes for electronics may not match up. Any advice on how that might work out?
4. I pretty much want to know what I will be in for if I pursue this?
5. The 1980 powerhead is a decent price, but should I holdout for something newer?
Any advice from people who have been down this road would be much appreciated. Thanks.
interalian
You can read my rebuild thread (in signature line) to see what you're up against. For the swap though, you'll be losing power. Your 1990 motor is a prop rated motor and makes about 115hp at the flywheel. The old one is 85 at the flywheel. I'd look for something newer, or rebuild what you have. Might just need one piston and a set of rings. Maybe...
spybot
I have been down that road you may come up against Stuck Power head bolts and they are a nightmare trust me on that one. They always come out but it takes a lot of effort and TIME.
100% With Interallian on this one you will lose about 40-50HP.
As he said your 90 was a 115 they changed from power head rating to prop rating around the mid 1980s.
Best to try and get your "90" power head fixed. or get a later model motor.
interalian
If you do go through my thread, let me know if the pictures are still showing or if the non-uploaded ones just show that P500 crap from photosuckit. I may go through and upload the pictures at some point.
nateintheboat
Hi guys,
Thanks for the replies. Interalian, I did read your thread and I believe that all the photos were still good. It was very informative. How many hours did it take you on the rebuild? I am still not sure I want to go that route. I might just look for a newer motor. I was hoping for a "simple" powerhead swap. I guess I did not realize that even if it fit, it is enough different that the HP would drop that much.
interalian
I started teardown of the 140 donor mid-March 2016 and had it running in the barrel at the end of May, and on the water June 3. Most of the time was fiddling around, cleaning parts, confirming what new parts were needed, ordering them, waiting for them to arrive, taking the block for machining 3 hours away etc. Probably with better planning the job would take less than a week.
If you're feeling adventurous, you could pull the heads (just the 10 larger bolts, leave the water jackets on) and inspect the bores. If within wear limits, rings and one new piston would be a pretty easy.
How did you determine the blown piston? No/low compression? You can also do a partial inspection of the rings on that piston by removing the bypass cover (4 bolts, cheap gasket) and see if they're broken/missing.
nateintheboat
The heads were already off when I purchased the boat, and the one piston broke a ring and scored the side wall of the cylinder. It is real ugly. I am not sure that boring it 0.030 over would take it out. That is why I am looking for a new powerhead, or new (used) motor. The problem is, I am on a pretty tight budget...
Thanks for the info though, I appreciate it.
interalian
Ugly is in the eye of the beer holder. Picture of the scored bore?
I know allll about budgets. I'm trying to do a basement on one.
nateintheboat
Here are some photos of the bad cylinder.
fetch
fetch
By the way, I am sorry that I am so slow at replying, the Suburban's AC just blew out and I have been trying to deal with that. If it isn't one thing, then it is another.
What do you guys think about the cylinder? Thanks.
Tagged
Resleeve.
It’s another option, anyway. I’ve never had one done, but I did the research before I broke about 15 bolts disassembling my saltwater block.
At at that point it became cheaper to keep looking for another old motor, that’s what I wound up doing. But if your block is otherwise in good shape, it might be worth it.
