horiconducker
Thread starter- Joined
- May 12, 2008
- 96
First off what a great forum, its so great ive never had to post up a question, the search function always did wonders. Ive got a pair of motors, model j100temxh (86' commercial for what i have researced). Well i started doing lots of maintance stuff, replacing fuel lines, fixing water in cylinders, checking timing. I have a clymer and seloc manual, cant find an oem for the commercial motor. Using joe's method tested first motor and came up with full advance at 24 deg.(with the 4 deg added) Went to second motor and thats when i discoverd the problem, there was not even enough spark for the timing light to pick it up. Through testing i found both starboard cylinders have a weak spark. Switched coil, powerpacks no change. Testing ohms of the charge coil using clymer method shows ohms low out of spec on the starboard side plug, but the port side is within spec. Manual states if ohms out of range replace stator. My questions
1. Is it posssible for a stator to be bad, and only affect one side, or do i need to start looking elsewhere. (timer base) I want to know for sure before i drop the coin for a stator or timer base.
2. What should the full advance timing be, my manual dont have the SPECIFICS of my motor. Thanks for any input
