V4 Crossflow Cooling water
weather8
Hi: I have the lower unit off and with a hose attached to the water pipe I get some water out of the center section of the mid section. Is that seal suppose to be water tight or is it ok for a leak at that location? Trying not to remove powerhead if I don't need to. Thanks Bill
interalian
Sounds normal. Here's a flow diagram.
