V4 90 Prop ?
zbuzz1959
Hi,
I have just bought a 1986 V4 90 with out a prop. My question is which prop do I need, pitch ?
Thanks
Chris
ezmobee
Re: V4 90 Prop ?
Depends on your boat. What ya got? I've got a 13-1/4 X 17 Turning Point Hustler on mine and I'm very pleased with it. You want a pitch that will allow your motor to reach it's recommended wide open throttle RPM range with your typical load. I believe with your motor that's around 5000-5500 RPM. If it can't hit that range, you could be lugging the motor which is bad for it. As, of course, is overevving it.
etracer68
Ensign
Re: V4 90 Prop ?
I would start with a 17 pitch also. I use a 13.2X17P SST prop on a 16ft glass V hull. With 3 adults, fishing gear, coolers, 12gal of fuel, and other stuff, I can run 5200rpm@36/37 mph(gps). I still want to try a 15p, but Im still looking for a used one to try.
Without WOT rpm, and mph, with your normal load, and of course type of boat, its hard to say.
zbuzz1959
Re: V4 90 Prop ?
Thanks for the info, The motor is on a 1981 Larson runabout 21'. I can get a 14/13 3 blade used. Not sure if this ws the stock prop or not. I'm new to the boat world.
Chris
ezmobee
Re: V4 90 Prop ?
That motor is going to be a real dog on a 21' fiberglass. That's pretty underpowered.
