TurboJet
Thread starter- Joined
- Jul 13, 2015
- 75
Evening all,
I have read a plethora of psi gauge install threads but unfortunately none of them are specific to my configuration.
I understand the V4 115 is a common engine, and this I am happy for due to the various (and plentiful) info here about them.
I also understand I have a "unique" configuration with my "adapter plates" and OMC jet pump configuration, and this is the "not so fun part" although I enjoy the boat and have had 3 great season with it.
I am just curious about installing a water PSI gauge into the proper place for my config.
I attempted to install a "T" into the water line in between the cylinder heads on my V4, but I am unsure if this would be an ideal spot?
After install and running the engine on the hose, I only see about 2PSI of pressure at idle.
I have ensured the tstats are open and the water hose pressure is 15PSI (in-line psi water hose gauge).
Attached is a pic of my water cooling system and where I tee'd into the water line in between the heads.
Can anyone shed some light on this for me?
I have thought about putting it in the incoming water line, but this wont help me with readings after the powerhead.
I have also thought about putting it in the tell-tell, but it will just be pretty much reading the pressure in my manifold before the powerhead (for this specific setup atleast)
(also noted is I have installed 2 head temp sensors/gauges for each head as well)
Any input is appreciated, especially from boobie or racerone , you guys are a great asset to this forum community.
Thanks for your time,
TurboJet
TurboJet
