v200 2.4L Carb Flooding
jtecker
I have a 1989 v200 BlackMax with wh-46 carbs. The number 6 carb is flooding out of the bowl vent at idle. I've rebuilt it several times, used a new gasket kit, clean every orifice with carb cleaner and compressed air. I switched the floats & needle valves with #5. Idles horribly and stalls in gear because of the flooding. Fuel coming out of the exhaust. Compression on cylinders 1-5 is 119-120. Compression on #6 is 110. I don't think that's low enough to cause this problem. Anyone have any suggestions as to what might be causing this? I have zero exhaust coming out of the prop hub at idle. 100% is coming out of the exhaust ports. Not sure if this is related in any way. Once up on plane it screams just fine. Thanks in advance for the help.
Iceman66
Re: v200 2.4L Carb Flooding
Have you checked the reeds on that nr 6?
jtecker
I've inspected them visually through the intake manifold ports with a flashlight but I haven't pulled the intake manifold. I didn't see any petals missing but I couldn't tell if one was leaking. I could switch the top and bottom carbs I guess to confirm that the problem is 100% not the carb. Would the blowback from a leaking reed cause a carb to flood? Thanks a ton for the reply.
Iceman66
Try the switch of carbs,then you know for sure its the carb or not.
Can be a compression issue here,but try the simple things first, have you tried a seafoam treatment?
jtecker
Problem solved!! I switched the top and bottom carbs and the problem followed the carb. So I took the carb apart (for the 3rd time) and found a small piece of crystalline deposit that somehow got through the valve seat but not past the needle valve and was keeping the needle valve from sealing when the float went up. Reassembed. No flooding. Runs great. Thanks very much for the assistance!!
Iceman66
Enjoy the ride!!!!
