tomtraveler
Thread starter- Joined
- Jul 18, 2013
- 1
How to release the trim cylinders inside the main housing. There is a set screw to hold the pivot pin and after removing it the pivot pin has an m6 thread on the inside. How do I remove the inside pivot pin holding the hydraulic cylinder to the main housing? Do I screw in a long m6 bolt for to push against the main housing to push out the pin? Screw in an m6 bold and try to pry out the pin? or is there something I'm missing here? It's very difficult to get at from the engine compartment.
