ttkcwilson
- Jul 17, 2010
- 1
After I've put the earmuffs on my I/O, how do I know the water is getting through the engine. Should the water be coming out the prop?
that's because (most likely) the cavity that leads to that hole is filled up with muck and plugging up that hole. i've had 2 mc-1's both had that cavity filled with muck. if ya dig out the muck. your's will have flow at that hole also..don't think you are supposed to get a steady stream of water from that hole on the front of the lower. I certainly don't have that flow on my MC-1.
