Chryslerman123
Thread starter- Joined
- Nov 18, 2016
- 87
I will continue to use anti seize. After having a plug seize in an aluminum head, I never want to have that happen again.
I do reduce the torque by 20% when I use it. I always use a torque wrench when putting plugs in, especially aluminum heads. Most of the warnings above are for people over or under torquing their spark plugs. Everyone uses a torque wrench when putting in plugs right?
I must chirp in the voltages the ignition uses are very high for them to operate correctly the spark plug in the head acts as a ground in the head so use nothing and torque properly if not used to installing spark plugs
Thanks Tim ( and all)!Post #11 should be a sticky.![]()
I would also say not an issue since even O2 sensors come with anti-seize. The only time you might have an issue is if that particular engine uses electronics that detect detonation using the spark characteristics. VERY few engines have this feature. When I worked for an auto electronics company we were starting to work on such a system but I left before we got to far into it.A non issue....help me bruce.
I was just reading on that system last night for the first time...Was the system called something such as Ion (ionization) sense ignition bias circuit. Kind of cool actually.The only time you might have an issue is if that particular engine uses electronics that detect detonation using the spark characteristics. VERY few engines have this feature. When I worked for an auto electronics company we were starting to work on such a system but I left before we got to far into it.
While I just added a few more from some other manufacturers for possible preparation of a sticky, I'm thinking this subject is a bit to controversially to place it somewhere because honestly we "could" (< but not going to) probably all get a bit to deep into a what about the torque spec value of using an low quality ratchet extension of 3 or 6 inches in length along with the use of Anti-Seize % torque values, etc. etc. etc. Specially since the use of any Anti-Seize is more of a personal preference which if used correctly doesn't really possess to many harmful issues all while inadvertently trying to prevent one possible bad situation.
Then the next question would be where/what sub-forum to place it as there are multiple engine sections.
Depends on what you are putting on the threads. For example, 20% is what Loctite suggests when using their product. There are engineering handbooks out there that specify the torque reduction depending on what you put on the threads.
Not sure what system they were using. In the beginning we were developing this cylinder pressure sensor and we would do signal processing on the frequency of the combustion to detect pre detonation.I was just reading on that system last night for the first time...Was the system called something such as Ion (ionization) sense ignition bias circuit. Kind of cool actually.
http://www.cycleworld.com/2015/07/23...ng-ionization/
http://www.google.com/patents/US6498490
