Using blind rivets under the waterline on aluminum boat in saltwater, are dissimilar metals a concern?
Batperson
Hello,
What is the best material for rivets under the waterline in saltwater? Do I need to stick with only aluminum (body and mandrel) or can I use aluminum body and steel mandrel or even a pure stainless rivet? Will dissimilar metals cause weird corrosion issues in the saltwater? Thanks I’m advance
airshot
In salt water yes...in fresh water only, SS and aluminum are fine
aluminum, steel and salt water make a battery
Ayuh,.... They make all aluminum Closed end pop rivets, which work perfectly, 'n don't leak,.....
