Using a Bravo Exhaust Bellow on a Alpha 1 gen 2 drive
brianteel
I am having a hell of time getting the exhaust bellow to stay on. I have heard of a few people using the Bravo exhaust bellow instead because it only mounts on one side. I have a 3.0 LX engine in the boat. Can some explain to me why I cannot or can use it.
HT32BSX115
Re: Using a Bravo Exhaust Bellow on a Alpha 1 gen 2 drive
Howdy,
There's probably no reason. The Alphas (GEN I, II) and Bravos all use seem to use
18654A 1 BELLOWS-Exhaust
There's no difference.
Regards,
Rick
Rocky_Road
You are probably thinking of the Mercruiser exhaust TUBE, which was designed to replace the exhaust bellows on the 6 and 8 cylinder engines. The tube is intended to reduce the back pressure, and is a popular replacement for the 4 cylinder (3.0L) owners. It only needs to be attached at the transom side and will slip into place on the drive side as the drive goes from the trailer position to the run position. They are sold right here at iboats!
http://www.iboats.com/Mercruiser-St...2479--submit.x.20--submit.y.8--view_id.268710
Happy boating!
brianteel
thank you for the information. I think i am going to go and get one of these.
saltlydawg
Hey Brian,
I opted for the tube in lieu of the bellow and the only time I notice it, is when I am trim all the way up.
With that said go for it and save hours of aggravation and the need to purchase a bellows tool.
