User Manual for 1992 Johnson 90hp
jwd000
Hi guys,
I am looking for a copy of the user manual for a 1992 Johnson 90hp. Something in PDF format would be ideal.
I have a copy of the repair manual but would like to get a copy of the user manual just to know all the things it should do and how to operate it the approved way.
Model no is: J90TLEND
I had a look on the Johnson site but the years did not go back that far.
Thanks
James
tashasdaddy
Re: User Manual for 1992 Johnson 90hp
your service manual should cover, proper starting procedure. the rest of the user manual is BS.
NelsonQ
Like TD said, user manual won't do much more than tell you the basic start procedures.
If you want the service manual, search ebay.com.
Item 190212567894 looks like the right service manual you could use but simply search for 1992 Johnson Manual and you'll get all kinds.
Be very careful on the CD versions, most are scans in a single document.
If nothing else, it'll cover basic maintenance like changing plugs and oil, etc if you feel comfortable doing so.
dajohnson53
Actually, not true in my opinion.
I always buy an owner's manual for the old outboards I buy. They are far more useful for the normal user than the service manual. They tell you the basics about the engine, fuel and oil, start procedure, spring and fall maintenance, specs for common user-replaced parts, etc. etc.. This information is formated for easy use by the typical owner/operater with the right amount of detail.
I also have service manuals for these engines, but there is actually very little in there that I use, because I'm a very poor and uninterested mechanic. I am a very good and interested user though! There is a difference.
The service manual either doesn't have the common, basic information (often - from my experience) or you have to wade through a lot of stuff to get it. The service manual is for people who actually want to fix their engine - which definitely is not the typical owner.
Just like the typical car owner needs the owner's manual to know how to operate everything, service intervals and specs. The typical car owner has absolutely no need for the factory service anual.
I definitely recommend that any typical owner (the great majority!) buy an owner's manual first. Afterall, it is what is given if you buy the motor new, no? The typical owner has a professional shop do anything that the service manual would be good for. That might not be you or many/most of the common iboats posters, but it is far more common among the boating public.
To OP: check ebay. Also look for an ebay seller called searayman13 and contact him - he's got a lot of used manuals in stock, many not listed on ebay. I've bought a couple from him and he's very good. If you can't find a used one, go to kencook.com and buy a new one. It will cost you more, but you won't spend a lot of time looking for it. I've done that too and have been very happy.
jwd000
Thanks guys,
I will check this out.
