I have two 12 volts running my trolling 24 volt 76 lb trolling motor. batteries are now going on four years (2013). last year the batteries started to die about 4 hours of constant use on low speed of five speed control. I want to know that if I should purchase a small 1200 watt generator, connect it to the battery charger for the batteries, will this continue to keep the motor running and keep batteries charged, what are the pros and cons of this thinking?
I can pick up a generator used for about $50.00. good 27/29 size batteries are $100.00
You seem to have a good knowledge of batteries hope you can help
thanks Larry
thanks Larry
