The Grayt 1
- Mar 30, 2010
- 51
We took our new boat out this afternoon and realized the drain plug was not put in (please spare us comments, we weren't the first and shouldn't be the last). The boat sat in the water for about 5 minutes and then we scrambled to pull it back out. The water level rose to just above the top of the oil pan. After it was out, we drained any water that had gotten in and were performing damage control. We found there was water on the dipstick end. So, the oil has been drained and the oil filter and spark plugs have been removed. There wasn't any apparent water in the oil and spark plugs came out dry. Now we are trying to determine what to do next.
Should we try to turn it over to determine if the starter is fried? Is it okay to turn the engine over knowing the spark plugs aren't in? Basically, what would any of you do from here?
