RODBOLT,
I have had a recurring problem with my Yamaha outboard and it has been at our local Yamaha dealer for 4 weeks and they haven't been able to solve the problem. I am entered in a fishing tournament for next weekend and need my boat and wonder if you might be able to help the mechanic and I figure out where to look.
Boat = 19.5' Bayliner
Engine = 1990 Yamaha 115HP ETLD
Motor has been rebuilt three years ago
Oil injection was disconnected as I run a two stroke kicker
Problem = Engine starts great, idles great, but when you get to between
4500 and 4800 rpm it starts to cough and stutter and then
backs down to 4000 rpm.
The first time it happened I changed the fuel pump. It helped temporarily and then the problem came back. Turned out that the primer ball was missing a spring on one end so I changed that. Problem still there. Tested the coils and found one defective, so I changed that and the motor ran beautifully. It hit 5600 rpm at WOT and hit a top speed of 48 mph.
This lasted about a month. One day after a couple of hours of tubing and water skiing, the problem returned again.
The dealer tested the motor and said everything indicated the fuel pump.
He changed it and tested it in the water and it was still doing the same thing.
The mechanic called Yamaha tech and they listened to what he had to say and said the same thing, the fuel pump is bad and maybe he had a defective off the shelf.
A new one has been put on but it has not been water tested yet. I believe it will fail again. I will be talking to the mechanic on Monday. Is there anywhere else in the fuel system that could cause this grief?
I am really stuck here and would appreciate any suggestions you might have on where else to look?
Thanks!
Thanks!
