Upper Motor Mount-81' 35hp Johnson
tirebiter
Was wondering if anyone has, or knows where I can get my hands on an upper motor mount<br />for a 1981, 35 hp Johnson outboard. We use it for the family pontoon. My brother-in-law is<br />doing the repair job, but has been unable to locate this part. I don't have the model<br />number as yet, as I am just starting the search. Can anyone help out there?<br /><br />Thanks Rick
rodbolt
Re: Upper Motor Mount-81' 35hp Johnson
Hello<br /> you must have a model number. most of the mount part numbers are different for different shaft lengths. may as well do the side moutnts and front lower mount to since you will have them apart. most any J/E dealer can order the parts<br /><br /> good luck and keep posting.
tirebiter
Thanks "Rodbolt", In fact, I've learned that we need the upper "front" motor mount, besides<br />the two other ones, right and left, they problaby should be changed too...<br />Guess I better get myself over there to get the right numbers...<br /><br />Thanks,<br />Rick
