midnightrider1818
Thread starter- Joined
- Aug 17, 2009
- 190
Ok, i have a alpha one generation one, every year I pull drive, this year the yoke seal was leaking, pulled retainer ring and pulled shaft. I still have the slip fit bearing/gear design, gears don't look too good but no chipped or broken teeth, worst gear is the drive gear, ill get a pic of it, however, the bearings and races on the driven gear don't look to healthy either, im gonna replace the yoke and seal to fix the leak, however I'm thinking I need to do those bearings on the pinion shaft/driven gear, will probably just run the gears for now, I'm sure the lower gears aren't much better, she gets alot of work on erie, 25 ft searay fisherman is what the alpha is moving
