upper gear shaft
blackz3
does the alpha one upper gear shaft turn when the boat is in neutral or does it have too be in drive or reverse.....and is it ok to run a boat in drive at low rpm with ears on
FreeBeeTony
Re: upper gear shaft
Yes, the upper gear shaft turns when in neutral.<br /><br />When you say run the boat in drive with the ears on do you mean in gear? If so, then I would say yes, but I would reccommend removing the prop for obvious safety reasons.........
