fabrimacator21
- Jun 28, 2009
- 286
Re: Upgrading mercruiser 350 v8 260 hp
The sportsmans are not ideal for your setup... 200cc intake runners aren't great for tq. Geared more toward a street rod looking for more top end then low end. You want 170-180cc heads(good tq).
Vortecs (170cc runners) can be had dirt cheap and will make the same power. If I were you I'd buy a set of vortecs that need a valve job and pay to have them rebuilt.... while he's in there to rebuild em have him do some port work. Vortecs are great torque heads and with some port work can really come alive on the top end.
http://performanceparts.com/part.php?partID=405559
Or you can buy a set of these ^^^^ which is the way to go IMO. 27 more cfm flow at .500 lift then the stock vortecs AND they will accept the older style intake manifold so your not stuck with expensive aftermarket vortec manifolds. They also have larger valves then stock vortecs. Price isn't bad either.
Depending on how much a valve job and port work is gonna cost I'd say your best bet is the RHS heads.
Sportsmans II Iron Heads from world products are saying its an improvement of 30-70 HP. I found some on craiglist for $300 for both. 1 Needs a small crack welded though. But prices on Summit raceing is anywhere between $400 and $700. Will this work? Good or bad idea?
http://www.worldcastings.com/products/sportsman-ii-iron-heads.html
http://www.summitracing.com/search/?keyword=SPORTSMAN II Iron Heads&dds=1
