Re: 1967 120 I/O water in unit lube question.
It is the small rectangular looking hole on the back of the top of the drive just below the top cap. That is where I have seen it coming out with my own eyes while skiing. Again, it seems like the higher speeds/rpms of skiing is when it pukes out the pancke batter. I'm pretty sure I'm just going to go through it and install all new seals since I am do to install a new water pump impeller too.
I already did that about 4 years ago with the advice of a local shop and them doing some of the work. Not sure that I'll have the shop touch it again since they broke the housing in the lower unit trying to remove it the last time, even though I took it to them since they had the "correct tool for the job". This is not a corroded old unit, it has never seen salt water, always garaged with limited use each year.
Maybe I should just do it all myself this time. If I can build this with my daughter and it know has 103K miles in nine years I would hope I can handle sealing the out drive?
http://www.meguiars.com/shiningstars/
My daughter assembled her cylinder heads herself so maybe I need her help:redface:
I need to read up on the pressure/vacuum testing procedure and do that. Is the testing done with the unit on the boat or after it is pulled? Also should a sealer be used on all the gaskets?
Time to build a pressure tester.
Also where is the best place to get seals and parts for some thing as old as my 1967?
Thanks all.
