UPDATED - PICTURES 1989 Yamaha 115 Advice please?
snsime
Hello,<br />UPDATE (pictures below):<br /><br />Thanks very much for your replies. We drove 70 miles today to look at boat/motor.<br /><br />Turns out it's NOT oil injected. Owner (1 year) advises that in ran flawlessly, acheived 50mph in 17ft bass boat, but auto choke didn't work, used manual choke on engine.<br /><br />He had a shop change plugs and bottom end oil, but other than that he's never had cover off. Motor has never seen salt, local small-water boat since new (tagged).<br /><br />By the pictures - is it likely that this IS an 88-89-90 Yamaha? Autochoke non-operative something that should give us pause?<br /><br />Owner is selling package below market value because it's middle of winter and it's sitting in his cottage's driveway. We feel we must act prior to season start as it will be sold be then - hence - we are considering a purchase with no leak-down, compression test. Seller is well-known member of community, we have reason to trust, still...<br /><br />Any insight on the year/durability/autochoke would be very much appreciated (again!)<br /><br />
<br />
<br />
rodbolt
Re: UPDATED - PICTURES 1989 Yamaha 115 Advice please?
works great never breaks, if you suspect its been in saltwater carefully inspect the shift shaft,especially where its visible just above the gearcase. if its rusted into an hour glass shape it can be costly to replace.
flounderman
I have a '89 115hp on my '76 Olympic ,it is a saltwater motor.The motor is as good as they come and better than most. I have never checked mileage [ha ha] but my GPS shows 36.5mph top speed with a 13x17(?) ss prop and 2 people ,38gals fuel, a 9.9 kicker and misc. gear in the boat. Check comp. with the throttle wide open, 120(+ -) would be a good number. Be sure you have water running to the motor when you do this, but I know you know that ,it is just a force of habit. good luck
flounderman
It sure looks good. It not being oil injected surprises me. Get the numbers off of the tag on the side that you are not showing us and then call a Yamaha dealer. It is on the motor mount where the steering shaft comes out. The auto choke should not be too big a deal. Yamaha's web site has a parts guide as well as a 1-800 #. Give them a call. As far as durability "as good as any, better than most".
carljh
Well mine is a 1990 injection model and it looks similar excpt mine has a box of electrickery between the cylinders and I can't see an oil tank on yours.<br /><br />
72hyc
<br /><br />
9oymf
<br /><br />Had no problems with mine in the two years I have had it. Always starts first time even after standing for 6 months, though I do run it until the carbs are empty.
snsime
Thanks very much guys. We've put a deposit on the boat. Wait till thaw and check it all out and give it a run.<br /><br />Thanks again
Ray Neudecker
That may be a newer motor than the pictures show. The consumer line did not have oil injection and used the older model electrics and cowlings.
bosavy
are u sure it's not oil injected mine is and it's a1988 . it's a little pump on the left side and mine has a manuall choheand a electronic one one the gearshift
jze1212
That looks like an oil tank on the last picture there, wouldnt that make it oil injected?
rodbolt
if its a C115 it was made with no oil injection and had a side mounted CDI until sometime in the mid ninties while the jet and precision blend shifted to the aft mounted CDI sometime earlier.<br /> so if it has a preffix of C ie C115, it never had oil injection if it is a plain 115 it did have it.<br />the last alpha character will indicate year for US motors from 84-05.<br />so an electric start c model trim and remote with a 20" shaft would look like this, C115TLRF. the same engine with oil injection will be 115TLRF.
