Idahogobbler
- Nov 9, 2013
- 17
I have a sea king 15 HP by Montgomery motors I have cleaned the carb and played with the float got it started and it sounded sooooooo much better now 2 more problems have evolved...
1st one is it can only run 10-1 min always different then will sputter out bulb will be soft and ican pump it until I can here it fill the carb bowl I took the fuel filter and diaphragm out filter was plugged horribly bad and diaphragm lood good to me but I don't know what a bad one would look like. started it up again sounded even better and steady ran for about 2 min then sputtered out again and that's were I noticed the 2nd problem
The 2 cylinders get so hot that it sizzles when water splashes on it. that's when I called it a night and don't want to go any further I know they will get hot but I have a feeling not that hot...
were do I start??
thanks
Colton
were do I start??
thanks
Colton
