Update on hydroelectric
ddaigle
Finally got my lower unit apart(1970 60 hp. johnson). DHadley was right , the piston in the pump seems to be sticking. It was very hard to get out. Polished and played with it and fits much better now. Gears appear to be ok. Want to put it back together but do i need new o-rings and gaskets? This unit was resealed about a year ago and all appear in good shape except solenoid cover which i destroyed on take apart. Can i forego the gaskets and use sealer or gasket maker? Having trouble finding gaskets for this motor.
ledgefinder
Ensign
Re: Update on hydroelectric
A seal kit should be readily available. If iboats doesn't have it, try boatfix.com or seatemp.com. The seal kit part number (Sierra aftermarket) is either 2690 or 2691, depending on whether you have the small or large-diameter propshaft.<br /><br />I'd reseal it, including the propshaft seals. If you want to take a chance though, the solenoid cover is the one gasket in there that would be the most likely to be OK replaced with just some Permatex.
nimmor
Instead of permatex go with something called Great Stuff. I believe it is made by 3M. We rebuilt a car engine and used it but two months later had to remove the heads and after we took the bolts out discovered we didn't need the bolts. That stuff made such a good bond we had to use a rubber mallet and beat the heads off. Like it's name it is great stuff. You will have to look at an auto parts store, they don't sell it at Wal-Mart.
