Unrepairable Boat ?
TerranceT
Hoping for helpful advice! I have a 2005 Yamaha AR230 that I bought (financed) a little less than a year ago. In August the starboard motor blew. I am now learning that a replacement engine for this boat is no longer made by Yamaha and the only aftermarket option will sell me a replacement if I supply a good core to trade. Mine has a hole in in it and does not qualify. My insurance does not cover mechanical repairs. I am really not sure what to do. The boat books at about $30k and is in amazing condition outside of the blown motor. I do not have the money laying around to pay off the loan, but as far as I have found out its pretty much a paper weight now.. Help!
jbcurt00
A google search pulled several 1.1l 140hp 4cyl engines for sale some didn't require a core.....
Maybe more than you'd like, but they are out there.... unless yours doesn't have the 1.1l 140hp....
tpenfield
Welcome to iBoats . . .
I am not sure your boat is unpreparable, but rather un-repairable. :LOL:
I'm assuming you want some advice regarding the engine. Have you looked for used/rebuilt engines? Any guidance from Yamaha on a suitable alternative. I guess you could convert to an outboard :unsure:
briangcc
Any boat salvage yards where you could get a replacement? Otherwise....maybe cruise the usual suspects looking for someone offloading a single screw Yamaha jet boat which you could use as a donor???
TerranceT
I'm not really sure about the 1.1l. It is a Yamaha MR-1 140HP. I have searched online and thought it wasn't going to be a big deal, maybe a little pricey but not impossible. I just don't really understand why the boat repair facilities I have taken it to initially tell me no problem, sits there for a month then they call to let me know they can't help and I need to come get it..
TerranceT
I believe this to be possible however I need to be able to find someone willing to do the work as I am far from being a mechanic...
base motors (without all the stuff) available in many are
You have now discovered one of the issues with " modern " corporations.-----Keeping a supply of repair parts in a warehouse is very expensive.----So they just do not bother anymore..
TerranceT
SBT will not sell an engine without a core trade. My core has a hole and is apparently unsalvageable..
There are hundreds of other sellers and you can get cores on eBay if needed
H20Rat
I was able to select that engine, add to cart, and make it up to checkout without once having core mentioned. I'm 99% sure they will sell it, you just won't get a couple hundred bucks back for sending one back to them.
