Unknown year of Johnson Sail Master 4hp
DCroatia2
Hello, recently I bought Johnson Sail Master 4hp made in Belgium and I was wondering how old the engine is. I found some list of model numbers -> year but I didn't find my model number so I would be very thankful if somebody could tell me the year of the engine.
Model number: BJ4BRHLCUD
Serial number: B7514058
DCroatia2
Thanks man I appreciate it. I would also want to know if that model is reliable and does it have any issues with running for a long time on low to middle power because I will use the engine for trolling.
interalian
Very reliable motor - it'll run endlessly for trolling or midrange power. If new to you, put a new water pump impeller on it unless you know it was changed within the last year or so.
DCroatia2
I don't know when the impeller was changed so I will buy a new one.
Thanks for info.
gm280
:welcome: aboard DCroatia2 to iboats...
If you want to see more info for your new-to-you engine, go to boats dot net and type in your engine information and see all the views for it.
