Bob Endeavor
Thread starter- Joined
- Dec 29, 2012
- 11
1996 Baja 240 with Mercruiser 7.4 carbureted. Last time we were out an alarm sounded and I can find no reason. Engine was cold, idled away from shore, accelerated to plane and alarm started. Gauges when this occurred, Oil pressure is in limit (approx 40), Temp showed high close to 200 but went down to 180 or so and alarm still sounding, Tach showing 3,000 or more RPM, Trim gauge does not work, Volt shows low at or below 11. Shut down for few minutes restarted and still loud alarm. Checked water flow as there was debris in water seemed OK. Brought boat home and started in driveway let idle for a while and no alarm. The volt meter does no longer works, have to knock on it to get it to move and then it onlyreads about 10V. I don't see how it has an out of limit sender. I previously had a problem the you helped with THANKS AGAIN! http://forums.iboats.com/forum/boat-...-safety-switch. Any ideas where to start looking? I will replace the impeller and thermostat as I'm concerned about the temp getting too close to 200 degrees.
Thanks in advance for your ideas.
