skydiveD30571
Thread starter- Joined
- Feb 13, 2012
- 1,042
2007 Seaswirl 210 br
VP sx-a drive
I wish I could say I am certain when this started but I cannot. I do have a good feeling that it started after I took the drive and gimbal ring off over the winter for maintenance. I noticed this summer that the steering wheel has to be held 1/4 turn to the left to keep traveling straight. Holding it where I used to will result in a slow turn towards starboard. Not a big deal, I got used to it. But this weekend I had to use reverse more than normal due to the docks we reserved and I noticed that turning full starboard at reverse idle the boat would pretty much not turn at all. Full port at reverse idle results in a quick swing around. I don't remember ever being limited to reversing in one direction on an I/O...
Removing and reinstalling the drive was pretty simple so I'm not sure what I could have misaligned to cause this. FYI, I've removed the drive a couple times but over the winter we had to change the gimbal bearing and to get better access we pulled the gimbal ring and pivot housing down. I don't remember there being anything to adjust on the steering arm but I might be mistaken.
If I remember right, it looks like the drive can't travel any more to the starboard side without hitting the trim pump there, so maybe I'm just crazy...
VP sx-a drive
