Under motor lightbulb heater (PIC)
IMHB
I made this tin can heater out of a coffee can.. I put a porcelain lamp socket in the bottom of the can, then I put a foot on the can to keep it from rolling...150 watt light bulb. I have plenty of room under my motor to accommodate the can.
The hull is aluminum.. If you have a fiberglass hull, I think you could place a piece of fiberglass insulation under the heater.. What do you think... will it work?
Re: Under motor lightbulb heater (PIC)
Ayuh,.... Welcome Aboard,.... Pretty nifty,....
It'd a been quicker to just Drain the block, 'n manifolds,......
jeffnick
I sympathize with the use of a heater. What if you want to take her out tomorrow - you'd have to winterize every time.
Trouble is, around here, when it get really nasty the power usually goes out.
I use a 750 watt electric heater in the bilge. I also have a remote reading thermometer sensor in the bilge so I can see the temp there while in the house.
I know, I know - I'm going to blow my boat up using a non-marine electrical device in the bilge. Guess I've just been lucky so far?
wrench 3
I've used the electric heater as a temporary measure if I'm too busy winterizing other peoples boats to get at mine. But only if the drain plug is out of the hull so that any fumes have a place to go.
How about using a magnetic block heater? The bulb idea makes me nervous. One drop of water and it goes poof!
funk6294
What about ball valves to quickly drain the block and manifolds??? I am thinking of doing this on mine. I have twins and the center two drains are a @&$$( to get to.
bruceb58
Only if you still have access to poke a wire in there to dislodge all the rust flakes that can block the valve.
funk6294
Thanks Bruce, I was thinking the same thing with the wire. With a single should be easy.
you could have just bought a $10 incandescent trouble light at harbor freight
