I need to replace the tilt knob on a 1987 Johnson 6hp motor. To access the knob, I need to remove the linkage and springs which are all held in place by a "shallow water drive pin". I followed the exact removal instructions as described in the original Johnson service manual, but I can't get the drive pin to budge. I've tried tapping it with a hammer and soaking it with liquid wrench. I'm afraid that if I use too much force I will end up damaging the pin and/or the lower unit. The pin is painted white and there is a little surface rust in the area. Perhaps the paint is holding the pin in place, but I am not sure. Does anyone have a suggestion on how to remove the pin? I was going to try and heat it with a map torch, but I was concerned that the heat might cause damage. Thanks so much!
