2shallow2sail
Thread starter- Joined
- Jul 28, 2008
- 30
Hi all- I realize this will always be a huge debate, but I'd like to concentrate on very small outboards (3.5 hp and under). I need to purchase a small outboard for my dinghy (8ft Achilles soft-tail) that will primarily be stored on the railing of my sailboat and used while cruising. I have a larger dinghy (12ft Avon SIB) that I use as my primary tender in the harbor, but it stays there when I go sailing. The 15hp on the Avon is acting up (thread in OMC repair section), so the small outboard will also serve as a backup power for the large dink. I used to have a 3hp yamaha on it that pushed it just fine, but that was stolen during Irene aftermath last year.
Long story longer, I have narrowed my choices to a brand new 2.5hp Suzuki 4stroke ($708 total delivered to my door) and a 90's model Nissan (tohatsu) 2.5hp 2-stroke (local guy asking $450). They are the same weight and both have 1 cylinder, both neutral-FWD and I believe both are CDI ignition. I am relatively experienced in small OB 2 stoke maintenance (carb jobs, fuel pumps, cleaning water jacket blockages, impellers, etc.). I have zero experience with 4 stokes. It is my understanding that adjustments to the new 4 strokes are difficult since they don't want you fooling with them because you can negatively affect the emissions rating. I am open to other motor suggestions, however I want to stay around the 30lbs mark. The motor will most likely sit for a week at a time between uses. Thanks guys, looking to purchase in the next 2 days.
