U-Joint Install (Rear), '89 C1500
Renken2000Classic
Changed that several years ago with an A/Z part (Spicer), but noticed recently it had some play back and forth on the yoke side (was tight in the driveshaft ears).
Took off today to charge the boat battery and maybe get it on the water tomorrow, one last time before winterization later this weekend. Only been out twice this season (both times in May). This U-joint job came first though.
Old joint had all clips still in place - spring type on the ears and C's at the yoke part (but Idk how oriented). After reinstall of the new joint (got another under warranty from A/Z), ALL PLAY IS GONE. I made sure to put the C's at the inner part of the yoke (vs at the clamps). There are no ridges on the yoke or clamps to capture the joint caps.
My main Q: Is it possible something (seals?) in the joint actually failed, or did I maybe do something wrong when I originally put the other one on (like put the C's at the clamp side or some such)? I would think a Spicer shouldn't fail for a long time, and don't want to take it back for the warranty $ if it was my fault. It seems fine reassembled off of the truck, but...
Thanks for getting through this long post, if you did, heh.
