U- joint bellows clamp position
1990 Glastron Cuddy Cab Mercruiser Alpha 1 Gen 1 Gimbal bearing, bellows and shift cable replacement.
All bellows are attached to transom. So now I do the u-joint bellows next on gimbal housing? And is the bellows clamp at the 2:00 position starboard side?
Is there a way in this forum to search my question because I'm sure this topic has been beat to death.
Thanks to all😀
Bt Doctur
better off installing it on the gimbal side first, ,then push it onto the transom side
