type of oil to use
jwf1968
i have a merc marnier ser#oc125187.new at this.and what type of lower end oil.
LubeDude
Re: type of oil to use
Marine Lower unit oil, I like to use a synthetic but still change it out at least once a season. Use new washers when you change it.
Texasmark
Wally world had 100% Syn Pennzoil lower unit oil. Be sure and get the "lower unit" oil. Otherwise you can go to your Merc dealer and get some Quicksilver lower unit oil. He'll have the washers too.<br /><br />Be sure you come out with old ones when you remove the screws; otherwise fish them out of the holes in the lower unit.<br /><br />Beins you said you were a newbie:<br /><br />You have a drain hole at the bottom of the skeg, below the gear box flare, and another one or two just above the anticavitation plate....flat plate just above the prop. Need a short screwdriver or tilt the engine to get the drain screw out then tilt it back level to drain. Level means the round gearbox part is parallel to the floor. <br /><br />Open all 2 or 3 ports and let old oil drain out; overnight wouldn't hurt. <br /><br />I think the fill is around 3 pints, maybe 3.5. If you go to a Merc dealer he will know how much you need.<br /><br />I like to prep all my tubes before I start as it makes filling a lot easier for 1 person; or get a helper to prep while you fill. You have to cut the end off the tube after removing the cap as it's sealed. I use a drain pan like for draining the crankcase on a truck and just prop the opened tubes against that till I use them.<br /><br />Stick the snoze of the fill tube in the lower hole and squeeze the tube empty. Quickly pull that one out and stick in #2 and so on until oil comes out the top hole(s). You'll spill some but keep it to a minimum and don't worry about it.<br /><br />Insert top screw with new washer in top hole and screw in snug. If two holes, do this to the forward one and then the aft one, which is just slightly higher. (Older engines only have one.)<br /><br />Then, having the lower screw/washer ready pull out the fill tube and quickly stab the screw. I screw it in with my fingers and then tilt the engine back up to tighten.<br /><br />Tighten all screws with a large bladed common screw driver real snug; like a bear grip on the screwdriver; hands only, no additional tools.<br /><br />That's it.......unless your oil is milky (homogenized water) or has visable water bubbles in it...Then you have more to do before you fill with new oil. Let us know of problems, if any.<br /><br />Mark<br /><br /><br />Mark
Texasmark
If that wasn't long enough, I forgot something. If a Merc dealer isn't close, and you go to ww for oil, it's in the sporting goods section; not in the automotive lube section.<br /><br />I have changed oil without new gaskets before, but I didn't like it. If your oil is dark and the seals look to be in good condition then you probably will be ok. They will probably be stuck to the lower unit. Don't remove them, just take a flashlight and rag and clean and inspect them in place.<br /><br />Mark
jwf1968
hey mark thanks for the great info.it will be put to good use.and thanks again greatly app
