rogerwa
Thread starter- Joined
- Nov 29, 2000
- 2,339
First question.. I have read a lot about the "fix" for porpoising by inserting washers at the ridie plate. I have read putting a stack of washers between the ride plate and hull will help this problem.. the question is do you put the thicker stack in front or the rear. I have read it both ways. I understand the stack in front works better on the gp1200, but the stack in back helps the 760. Is there anyone that has done this on the GP760 and benefitted? If so did you install in front or back?
Second Question.. Last time I had my 760 out at my cabin, I went to start it and take off while cold and it caught and then died. I had drifted closer to shore where there was some weedy junk and then I tried it again it caught and killed. I hit it again and it just clicked. I didn't think it ws the battery but I tried jumping it anyway - no go. After I pulled it out of the water, I found a weedy mess hanging out of the intake and cleared that away but have not yet gotten under there to see if it clogged further up there. Is it possible the weeds got sucked in there and bound up the impeller to the point it can't move?? I am guessing that it got stuck while the bendix was still engaged and it cannot budge.
Thoughts?? I am going to get under there tonight but I am new to skis and do not yet know what things can happen..
Thanks
Thanks
