Long time listener...first time caller. 1978 Johnson 15 hp. Smacked something underwater...really hard. Motor still runs great however the prop won't spin under any rpm. I'm pretty sure the hub isn't spun. I did try and knwon good prop. Thinking the worst that the lower unit is junked, I drain the oil over a magnet, no metal nothing. Oil looks pretty good. I changed it this winter. I drop the lower unit and I find that the lower end of the upper drive shaft is twisted. (told you I hit something hard.) Spinning the prop, with the upper drive shaft out, I hear no funny noise, no metal on metal sounds. The same when I put it in forward or reverse gear. When I try the same thing withn the shaft in and in gear I can't get it to spin. Looking for opinions or advice here. I hoping the extent of damage is simply the twisted shaft. I'm going to take to the local dealer and see if he will drop a good shaft in there to test for further damage. Anyone else have a similiar problem and what was the outcome?
Thanks in advance.
Thanks in advance.
