twin bracket mounting
henault
Two years ago, I got a 'Fisher-like' boat :
V transom,
length 21', beam 9',
dry weight 2.5 tons,
one outboard Suzuki DF115,
one 3 x 13.5 x 15 prop.
Due to the weight, speed was about 18 kn @WOT (5500-6000 rpm)
Knowing that 115 HP were not sufficient, I found a good deal for a second suzuki DF115, same engine, same prop, NO counter-rotation.
The result looks good : 20 kn @ 4400 rpm (26 kn at WOT, hard to maintain due to torque).
But I noticed that, at 4400 rpm, there were on the rear, like 2 walls of water, about 1 foot high, on each side.
I remembered a picture showing those 'two walls' as an example of incorrect height for the engines, but I cannot remember if they are too high or too low.
The service man put the two engines so the A.V. are exactly at the level of the limits of the 'V' (see the picture), as far away each other he could.
Anybody to tell me if engines mounted too high or too low ?
Thanx in advance
ddrieck
Re: twin bracket mounting
Looks to me like you could stand to go up a couple inches and still have enough water intake to mantain an adequate cooling pressure in your outboards. You might concider intalling a hydraulic jack plate on each outaboard. You could then raise or lower your outboards to match the conditions you are running in. Raise them up for max speed in fair conditions and lower them down for a better bit in rough and high wave conditions. Just be sure to use a water pressure gauge so you can tell if your getting enough water to cool things down when your running them higher.
The inland lake bass boat guys use hydraulic jack plates to run as fast as they can go. The off shore guys use them so they can get the lower unit lower in the water for max bite in the water. These units offer you the best of both worlds without having to constantly move your outboard up and down manually.
This website has some fair pricing:
http://www.transom-jacks.com
your props may also be wrong for your setup. You could ask in the prop section of the forum. I don't know much about props
Dhadley
Looks to me like they're pretty low but a lot depends on what props you're using. Looks like the toe in is off too.......
