twin 1998 175 evinrudes cold
hydrasports
My twin (carbed) 1998 175 evinrudes run cool,the temp needles barely budge when cruising yet when im idling the temp reaches normal (the temp needles reach the middle between green and red. I changed the thermostats and it seemed to help a little but not much. These engines are leftover with zero hours, anyone have a clue what the problem mite be ? when I run off garden hose they run at the right temp. thanks
jegervais
Re: twin 1998 175 evinrudes cold
As "comfy" as those gauges make many people feel, I don't put much stock in them. Those engines should idle at 140 (+/-15) and not exceed 160 at WOT. On most all the engines I check temp on, they run 145-ish at idle and 125 or less at WOT - this is in about 70 degree water, if the water is warmer or cooler than this, the engine will run a few degrees warmer or cooler too. The engine temp is normally checked at the top of the thermostat pocket. I use an infrared temp gun when I'm servicing these things.<br /><br />When the water pressure builds as you increase rpm, the thermostats lift off their seats and floe a very hi volume of water, that's why they run cooler at higher rpm. What you are seeing sounds quite normal to me. I would verify the operating temperature as outlined in the service manual - DO NOT run the engine on a garden hose when performing temp checks.<br /><br />If all is well, then that's the way your gauges read.<br /><br />-John
