turningpoint hub question
dwai
i have a 2008 tohatsu 50hp md50b and cannot figure out what hub i need for a turning point prop? does turning point make a hub for this model? thankyou in advance
SkiDad
Re: turningpoint hub question
if they don't i believe you can use any of the other hubs that fit from other brands.
Texasmark
Or go to the top of the page and select propellers. Go to the page, put in your engine parameters and pull up the props page. Surely there will be a TP Hustler on there. Select it and look at the top of the page where the prop you want is featured. If you need a special hub it will/should be there along with special thrust washers if needed, new prop nut and the sort. Was for me.
Mark
