Turning AQ260 by hand?? No nut!!
arfaname
Hi All,
As many tasks when working on an engine require me to turn it over by hand I would normally just use the bolt in the front of the crank . On my Volvo AQ260 (350 chev) I have th eraw water pump assembly installed directly to the end of the crank shaft. I can not for the life of me find a way to turn it over by hand. I want to be able to accuratly stop it turning for things like timing marks, TDC and checking drive ratio.
Do you fellas have any ideas on what I can grab onto to turn it over. Punching the starter is just not accurate enough..
Thanks
Sean
Re: Turning AQ260 by hand?? No nut!!
Ayuh,... remove the sparkplugs, Tighten the belts, then use the alternator bolt...
arfaname
Thanks Bond-o. I have tried swinging off the alternator bolt however I did still have plugs in and the belt was only at normal running tension.
I'll give it a shot.
