Re: Turbo, or Stiletto??? 3 or 4??? (Kenny/Dhadley)
Performance with no setback or engine heigth was minimal compared to how it turned out.<br />The setback can do a couple of things..1 is it changes the CG of the boat which can change how much wetted surface you have, and yes, it does get it back in a somewhat more stable water condition and that in itself depends on the hull structure and how true the bottom really is, and I can tell ya first-hand, rivet heads don't help the situation.<br />Adding setback can also change the required prop, but I don't think you'd have any problems with the Stiletto...you're starting with a good prop.<br />I ran alot of different props on the 115...the Raker, Nauticpro, Ballistic, Michigan match, some merc aluminum props, several OMC SST's and a few other odds and ends, oh, and 1 powertech I bought on ebay, then found out it was a copy of an SST original. I couldn't pull the Raker enough RPM until I added the plate and got the engine up...Dhadley also walked me through plugging the top 2 holes on the lower unit water pick-up, by tapping then inserting machine plugs loc-tighted in place, then filled over them with some body work and repainted, but there is a 1/8" drain hole below the 4 main water inlets, Dhadley had me drill that 1/8" hole out to match the others in size and then done some grinding to make the entry pockets match those above. This is a great way to gain a couple of inches in heigth without loosing water pressure, and I was able to raise the engine enough to really make that Raker come alive...the hull responded very well to the mods and all worked out quite well. from the RPM the Raker originally ran (5400), I gained about 175-200 just raising on the transom, but after the plate and water inlet plugs and some more heigth, I ended up between 5750 and 5800RPM.<br />So I went from basically 40MPH to right at 48MPH, and during Feb. of 1 year, I did see 49.2MPH. Now I had done a few other items to the engine as well..at my altitude, I went 2 steps leaner on the main jets, advanced timing by about 3 degrees of max, which most will recommend against both of these to some extent, but through the years(22) of my Father selling Jonnys and Glastron boats, he found this to be the best combo (jets and timing) on the V4;s for 3600-4000ft.<br />I think there is more potential in your rig, it's just a question of how much do you want to do????
