Turbo Lube Hubs
mailman1
Has anyone used these hub that use oil instead of grease? Are they any good?
Linc33
Re: Turbo Lube Hubs
Wow, no responses yet. I thought *someone* out there would have these hubs installed and have some comments. I am interested as well to see how they perform.<br /><br />-Linc
ddaigle
Re: Turbo Lube Hubs
Dont personally have them on my trailer, but down here in the salt they seem to be putting them on all the new trailers. Have talked to a few people that have them and they seem to like them. Being able to see the oil level and condition seems to be a big plus. Unless they spring leaks, seems to be a good idea, but dont know any long term reports.
craze1cars
Re: Turbo Lube Hubs
I inquired about these things on a number of different boards and am coming up just about as dry as you have. Have considered making the switch myself but decided not to. Here's the general word on the street from what I've gleaned:<br /><br />Pros: They work exactly as advertised. Bearings will last longer and run cooler, you know with a 1/2 second visual check if your bearings have sufficient lube or not.<br /><br />Cons: If/when they do leak at a seal, especially while running 70 mph down the highway, that watery gear oil just flows right out onto the ground fairly quickly and you go straight from "fully lubed & cool" to "red hot melted bearings" without even knowing it happened. If you have a bad seal on a conventionally greased bearing you have quite a significant grace period before they melt down since the grease is much thicker and sticks to the bearings better, and has a much more difficult time sneaking past a questionable seal.<br /><br />And if you're thinking of retro-fitting these turbo-lubes onto an older spindle, I understand that it is extremely critical to have a perfectly smooth and ungrooved spindle to allow the seal to hold properly. A lot of aged trailers may leak very easily as opposed to installing one of these kits brand new from the factory.<br /><br />My decision to NOT make the switch comes from the simple fact that in over 25 years of long distance towing boats in summer and snowmobiles in winter, I've never had a problem with the conventionally greased bearings. So why spend extra money to mess with what works? I carry a spare assembled and lubed hub and can change it out in very short order on the side of the road in the unlikely event that I have a failure someday (never have...most likely because I carry a spare :p ) Then again, I'm better at annual maintenance repacking than most trailer owners so I never give them a chance to fail. But maybe for the low-maintenance crowd, these are a good idea since I'm sure they're easier on the bearings over the long haul if you don't repack as you should. Better fuel economy is their other claim. HA! If they can get my truck from 12 mpg while towing to 12.05 mpg while towing, I'll be stunned...and I'll still have a lighter wallet! Those kits are a little salty compared to an occasional $5 bearing and seal.<br /><br />Well....there's my input. Maybe it helps. But I don't have 'em myself either.
mailman1
Re: Turbo Lube Hubs
Thanks for the replies. I went with the old standard hubs with bearing buddies. I feel safer now.
phatmanmike
Re: Turbo Lube Hubs
i have turbo lube hubs and will not buy them again. they leaked like a civ. ive replaced the bearings on one wheel twice, and the oother once.<br /><br />i have since added zerk fittings to the covers and have turned them into BEARING BUDDIES for about 50 dollars too much.
Gone Again
Re: Turbo Lube Hubs
If you want a hub lubrication system that is second to none, check out www.liqualube.com. This system uses the original hubs and provides a way to seal the imperfect spindle area that is prone to leak with other liquid systems. The lube used is synthetic and creates more lube when mixed with water. The cap used is designed with a spring loaded diaphragm so backing a warm hub in cold water will not draw in water. I have installed many of these systems and have not had a single leak. You will not be sorry. Give them a look. Tom
rottenray6402
Ensign
Re: Turbo Lube Hubs
I have the hubs that use gear lube and have run them for 2 years now. Initially I had a leak at the seal on one side so I removed the hub and sanded down the spindal until it was spit polish clean. I reassembled the hub and have had no trouble since. I tow at 65MPH on the Throughway here in NY and now when I stop at the rest area I don't rush back to feel how warm the hubs are. My big disappointment was the hub was larger than the ones that were on there so I had to buy new wheels that had a larger center hole. What should have been about a $80.00 cost turned into $300.00 when it is all said and done.
QC
Re: Turbo Lube Hubs
There is a good article in Trailer Boats mag this month about installing those hubs.<br /><br />I love running back to the trailer and touching the hubs when I stop too. I especially like the guranteed slime on my hands heading directly to the steeering wheel . . .
T S N
Re: Turbo Lube Hubs
I just put turbolube hubs on today.<br />One store only had one, so I installed it then drove to the next store to get the other one.<br />after about 5 miles I checked temp with the scientific finger touch method. The turbo lube hub was cool, the other hub was warm.<br />This is on a new trailer so I will see how they hold up over the long haul.
