Turbo 1 prop ?
seawallkid
Hi Guys, I have a 23' Wellcraft Eclipse 3900 lbs unloaded. Mercruiser 260 hp, Alpha 1, gen 11. It currently has plain Quicksilver stainless 17" P. It is turning 4600 - 4900 rpm depending on the lake I go to ( altitude ) and conditions about 48 mph ( stock speedo, no gps ). After a lot of reading threads here, I am looking to go to a Turbo 1 prop. I am wondering what the difference will be on RPM,speed, lift going from the quicksilver to the Turbo 1 ? I am considering going up to a 21" pitch with the turbo. ( the boat came stock witha 21" pitch mirage ) But I don't want to overprop because of the Altitude. 3000 to 3500 or so feet. . I am looking for more speed if possible, but also do tubing so don't want a dog out of the hole. Look forward to your replies Thanks, Rich
walleyehed
Re: Turbo 1 prop ?
21P in the Turbo will be WAY too much.
Which quicksilver prop are you running?? there may be some better options...
seawallkid
Re: Turbo 1 prop ?
OOPS! Sorry I meant 19" Pitch, 1 step up from the 17".( It came with a 19" mirage when new) It is a quicksilver part # 48-16314 a4 17p which I read at some prop site was a cheap stainless replacement prop from Quicksilver. Look forward to your help Walleyhed.
walleyehed
Re: Turbo 1 prop ?
Let me dig my Merc book out and see what that number is....I can then compare and see what may be the best option...Hang tight!
