Mercruiser 4.3 Alpha
S/N OW626893
So when I was winterizing, I noticed some discrepancies between the parts lookup diagrams and my engine. I was hoping you guys could help me clear it up.
Three pics attached.
Standard cooling system and thermostat and housing are directly from the parts catalog. My tstat is a picture (not a great one) of my actual unit when I had it off for winterizing.
Tstat and housing shows only 4 hose connections to the housing. That is clearly wrong. My housing has 6 hose connections. The standard cooling system diagram shows what appears to be the correct housing with 6 connections.
Also, the tstat and housing diagram appears to show a gasket between the housing and the block and seems to show that the thermostat comes out of the bottom of the housing.
As far as I can tell, there is no gasket between the housing and the block and the thermostat does not come out of the bottom. It looks to me like there is a plate on the top of the housing that would be taken off to allow the the tstat to come out of the top.
Can you guys help me with the proper assembly of my tstat housing.
Thanks!
S/N OW626893
Thanks!
