Please help.............no experience here.
I have removed the locking screw with an allen wrench and the threaded cone. Under the cone was a large spanner type washer which lifted out. The next thing as is appears is the prop itself. Do I need some sort of puller to remove the prop from the prop shaft or should the prop simply pull off? It seems pretty tight and looks as though it may call fall a puller of some kind, but I'm not sure. Thanks for any suggestions, George Santee, CA
