Re: Trying to rebuild 18 hp Johnson
Also of note. The pics from the vary first page of this thread the first pics showing the motor. Is how the motor came to me IE In pieces. The PO clearly was looking at what all was wrong with this motor. After doing the reseal of the LU I noticed one day that the cradle was missing from this motor, and found it a little odd that that piece was missing. So someone had been in there , and removed it or it broke and was not replaced, And in that case they got in there and took out the pieces IDK. But tonight when i looked up the LU gears dog,and pinion. The only site I could find listing part numbers for 59 johnson 18hp was marine engines. and all the numbers they give when looked up anywhere where there are pictures. The gears do not match my gears. I have gears with 26 teeth all the pics from the part numbers listed on marinengines have 20-22 (Kinda hard to count on the pics), but it can clearly be seen there are less teeth on the pics then my gears. The flat spots at the peaks of the gear teeth is wider than mine(which is what drew my attention first and made me count). Is it possible the PO put a different set of LU gears in there. Losing or forgetting to put back the craddle in the process, and that be my problem with the linkage not working properly or whatever happened the wrong gears set for this motor. If need be I found a NOS forward gear and bushing for 16.50 NOS rev gear for 10.00 and a pinion NOS for 22.99. All These have the different teeth pattern would they work as long as i got all of them.
