trying to find parts on Iboats
chewie1997
for my 1982 35hp evinrude. I found the carb kit but have not been able to find the impellar. I tried using the "Narrow your search" field. The factory evinrude part number is 0388702 ($20 from evinrude and in stock).
Should I order the carb kit w or w/o the float?
Should I get just an impellar or the water pump repair kit (include impellar from evinrude and costs $50)
The evinrude carb repair kit is $30. Should I order everything from evinrude or is the Sierra or Mallory kits just as good for less money?
Final question. I want a factory service manual. There is a SELOC manual that covers the 1982 35hp. Which manuals are the most detailed? For my car and motorcycle I have the OEM service manual (by helms) and would like an OEM service manual for this outboard. I couldn't find a Ken Cook manual (looks to be OEM) covering the '82 model. thanks for your help again.
chewie1997
Re: trying to find parts on Iboats
thanks TD,
I just ordered the waterpump and carb kits you recommended. I changed the manual to the 35rcn (mine is a e35rcnd). I also ordered the 13" pitch prop CAtransplant recommended. Thx for your help again. Hopefully the manual can begin to answer my questions from now on! Thx again.
tashasdaddy
it will help, but not answer all of them. if nothing else just confirm your thoughts here, and share what you are learning with others.
CATransplant
Don't hesitate to ask questions here. We'll help all we can.
